1991 Headlight removal
Old Jun 3, 2004 | 11:46 PM
mmcdermot's Avatar
Default 1991 Headlight removal
I just picked up a 1991 Galant for my son. The lower rear of the front quarter panels is rusted. In trying to take off the front fender to repair the rust I have found removing the headlight to get to fender bolts to be impossible.
Sounds like a stupid question but how do the front headlight and side light get removed. I can not see any obvious bolts to remove.
Help?
Old Jun 4, 2004 | 11:05 PM
sergei5150's Avatar
Default RE: 1991 Headlight removal
I had the same problem too, when I changed my headlights to jdm . But I found out by inserting a screw driver (flat head) between the fender and the turn signal light or park lamps ( be careful not to chip the paint or dent ur fender) u can push it towards the outside. if u already remove that then u will see the headlights bolts. but take note there is a spring that holds these lamps (that's why there's a little resistance when u push it, u may also look for it. one is near ur battery on the right side and the other is on the left. hope this helps......
mlahrens
Jan 29, 2016 06:54 AM
RTam87
4th Generation
May 19, 2012 08:34 PM
morourke2@juno.
Mar 15, 2004 01:53 PM
DarkrealmX
Feb 15, 2004 07:47 AM
Pascal
Feb 10, 2004 01:46 PM
