1996 Galant Timing belt replacement procedure?
Old Feb 28, 2005 | 03:23 PM
galanturd's Avatar
Default 1996 Galant Timing belt replacement procedure?
Hi Folks. I'm helping a friend replace the water pump on his 96 Galant, 2.4 ltr 4 cylinder. We're in the process of putting it back together and have hit a snag with the timing belt tensioner. We're using the Haynes manual and the procedure to apply the proper amount of tension to the timing belt is not clear. Obviously we want to get this part right. So does anyone out there have any experience with this procedure? Any advice appreciated.
Old Mar 24, 2005 | 02:52 AM
pops55's Avatar
Default RE: 1996 Galant Timing belt replacement procedure?
just did timing & pump R&R on '95 LS, the tensioner should do it for you, just pull wire pin out and the spring load on the tensioner should do the rest. I've got the Haynes manual but unable to locate it just now, rennovating garage. will post when i locate it.
lars
1st Generation
Jan 18, 2014 12:04 PM
Mazdaspeedster
Jan 14, 2013 06:57 PM
mrvivona
Jun 12, 2011 12:08 PM
mrvivona
Dec 9, 2009 06:50 PM
JNMathews
Sep 29, 2009 08:49 AM
