Galant VR-4 Specs
Old 07-18-2005, 02:18 AM
JDMVR43000's Avatar
Default Galant VR-4 Specs
What are the specs for the Galant VR-4(horsepower,0-60time,1/4 run)
Old 07-18-2005, 03:34 AM
Default RE: Galant VR-4 Specs
JDM or USDM?
Old 07-18-2005, 03:55 AM
JDMVR43000's Avatar
both
Old 07-18-2005, 03:57 AM
JDMVR43000's Avatar
or either one
Old 07-18-2005, 05:05 AM
Google is your friend....
Mitsubishi Galant VR-4s were imported to the United States in 1991 (2000 imported) and 1992 (1000 imported) each of which came with a numbered dash badge and key fob. Production numbers for Galant VR4s sold elsewhere in the world are unknown but guessed to be a couple thousand in total. Primarily sold in Japan, some were also exported to New Zealand, Australia, and other countries in the area. Some have even managed to make it to Europe and central Asia as gray market cars.
Basics
Vehicle Type: front engine, 4 wheel drive, 5 passenger, 4 door sedan
Base Price: $21,000
Available Options: Power sunroof (code PI, $685), compact disc player (code EC, $509), graphic equalizer (code EG, $316-$343)
Standard Accessories: power steering, windows, and locks, A/C, cruise control, tilt steering, rear defroster
Engine
Type: turbocharged and intercooled 4-in-line, iron block and aluminum head, liquid cooled
Bore x Stroke: 3.35in x 3.46in (85.0mm x 88.0mm)
Displacement: 122 cubic inch, 1997cc
Compression Ratio: 7.8:1
Engine Control system: Mitsubishi electronic with port fuel injection
Emissions Controls: 3 way catalytic converter, feedback fuel-air-ratio control (oxygen sensor), EGR
Turbocharger: Mitsubishi TD05H w/6cm turbine housing
Wastegate: Integral
Maximum boost pressure: 11.1 psig
Valve Gear: belt driven double overhead cams, 4 valves per cylinder, hydraulic lifters
Power (SAE Net):195bhp @ 6000rpm
Torque (SAE Net): 203lb-ft @ 3000rpm
Redline: 7000rpm
Horsepower/liter: 97.6
Recommended fuel: Unleaded premium
Drivetrain
Transmission: 5 speed
Primary reduction ratio: 1.275:1
Secondary reduction ratio (front diff): 3.866:1
Transfer ratio: 1.090:1
Rear axle ratio: 3.545:1
True final drive ratio: 4.927:1 (multiply primary x secondary for front, multiply primary x transfer x rear axle for rear)
1st gear 2.846 34mph @ 7000rpm
2nd gear 1.684 58mph @ 7000rpm
3rd gear 1.115 88mph @ 7000rpm
4th gear 0.833 117mph @ 7000rpm
5th gear 0.666 130mph @ 6200rpm
Reverse gear 3.166
Dimensions and Capacities
Wheelbase: 102.4in/2600mm
Track, F/R: 57.5/57.1in, 1460/1450mm
Length: 183.9in/4670mm
Width: 66.7in/1695mm
Height: 55.5in/1410mm
Frontal Area: 20.8 sq ft
Coefficient of drag: 0.34
Ground Clearance: 6.1in/155mm
Curb Weight: 3250lb
Weight Distribution, F/R: 58/42%
Power/weight ratio: 16.7lb/hp
Fuel capacity: 15.9gal
Oil capacity: 4.0qt
Water capacity: 7.4qt
Chassis/Body
Type: unit construction with 2 rubber isolated subframes
Body material: welded steel stampings
SAE volume, front seat: 52 cu ft
SAE volume, rear seat: 43 cu ft
SAE volume, luggage space: 11 cu ft
Front seats: bucket
Seat adjustments: fore and aft, seatback angle, height, lumbar support
Sound System: Mitsubishi AM/FM stereo radio/cassette, 6 speakers
F: independent MacPherson strut located by a control arm, coil springs, anti-roll bar
R: independent, 1 articulated trailing arm and 2 lateral links per side, coil springs, anti-roll bar
Steering
Type: 4 wheel rack and pinion, power assisted
Ratio: 17.8:1
Turns lock to lock: 2.5
Turning circle curb to curb: 34.8ft
Brakes
F: 10.4 x 0.9in vented disc
R: 10.4 x 0.4in solid disc
Power assist: vacuum with anti-lock control
Wheels and tires
Wheel Size: 15 x 6.0in
Wheel type: cast aluminum
Tires: Bridgestone Potenza RE88, 195/60HR-15
Projected Fuel economy
EPA City Driving: 19mpg
EPA highway driving: 25mpg
Estimated range, city/highway, miles: 302/398
Performance Numbers
0-30mph: 2.1sec (Car and Driver), 2.4sec (Motor Trend)
0-60mph: 6.8sec (Manufacturer), 7.0sec (Car and Driver), 7.3sec (Motor Trend), 7.9sec (Design News)
0-100mph: 21.9sec (Car and Driver)
Standing 1/4 mile: 15.2sec @ 89 mph (Manufacturer), 15.6sec @ 88mph (Car and Driver), 15.6sec @ 89mph (Motor Trend)
Top Speed: 130mph (Manufacturer), 132 (Car and Driver), 130 (Design News)
Skidpad: 0.78g (Car and Driver), 0.80g (Motor Trend), 0.77g (Design News)
Braking 70-0mph: 183ft (Car and Driver)
Braking 60-0mph: 130ft (Motor Trend)
Slalom: 60.8mph (Car and Driver), 64.9mph (Motor Trend)
Old 07-18-2005, 04:39 PM
JDMVR43000's Avatar
thanks, now I want one even more!
Old 07-18-2005, 07:33 PM
Click Here
Info should be in that link.
daftmajin
09-08-2006 07:28 AM
SmokeShow
04-18-2006 12:32 AM
rico
1st Generation
02-16-2006 03:28 PM
tkrahel6
01-17-2006 06:25 PM
bobdilts
11-14-2005 02:44 AM
Quick Reply: Galant VR-4 Specs
