2001 Galant Engine Mounts
Old Oct 16, 2011 | 04:25 PM
inscarguy's Avatar
Default 2001 Galant Engine Mounts
i have a question. my step daughter needs two engine mounts changed on her car(the lower ft left and lower rear). she has the 4cyl. are these a reasonably straight forward change or does the engine have to be suspended. im going to do all four of them. if two are gone the others are not far behind. thanks in advance.
Old Oct 17, 2011 | 10:33 PM
mxmikie's Avatar
just jack the eng up
Old Nov 9, 2011 | 10:02 PM
kenball1980's Avatar
Yeah, I just replaced all four of mine. You should use a hydrolic jack with a block of wood under your oil pan to jack the engine up. The front one is very easy. The rear is allot more complex. On mine, I had to remove the air intake box with the air filter and disconnect it from the throttle body. A very long socket extension makes getting the bolts that go into the frame out ALOT easier. Only disconnect one at a time, getting them lined back up was the most difficult part for me. Go for it! Let us know how you made out!!
mikemitsu
Feb 17, 2014 01:50 AM
Ralliart3000
May 21, 2008 07:13 PM
Polonez
Nov 22, 2005 04:22 PM
duncombemu
Jul 11, 2005 08:44 AM
jrmdir
Jan 22, 2005 07:58 PM
