'99 Montero Engine & Trans Mounts
Old Jan 17, 2005 | 06:01 PM
jrmdir's Avatar
Default '99 Montero Engine & Trans Mounts
1999 Full Size Montero - 104,000 Miles
Recently I am experiencing a good deal of secondary movement somewhere in the front of my Montero after hitting bumps. I suspected bad shocks but have confirmed that this is not the problem. Also have ruled out suspension bushings - or at least they appear OK.
I have noticed that the engine/trans is very easy to move and that it seems that this massive unit may be oscillating up and down for a few cycles when the chassis hits a bump. The rear mount is so soft that I can move the trans up and down just by pushing on it by hand. As far as I can see, none of the mounts are torn or separated - just really soft. Does anyone know if they are meant to be so flexible, or is there prececdence for Montero mounts going soft with age. Any other tips or possoible suspects would be greatly appreciated.
Thanks,
jrmdir
Old Jan 22, 2005 | 07:58 PM
DarkManC's Avatar
Default RE: '99 Montero Engine & Trans Mounts
Sounds like the source of your engine movement is coming from your engine mounts.
They are not very expensive to replace and will solve this problem that you are having.
The rubber part of the mounts have begun to deteoriate due to age and engine wear such as oil leakage or such.mounts are a part designed to wear out.
Ralliart3000
May 21, 2008 07:13 PM
Silver00GT
Oct 5, 2007 09:19 PM
dwdwdw
Dec 20, 2005 03:56 PM
Polonez
Nov 22, 2005 04:22 PM
duncombemu
Jul 11, 2005 08:44 AM
