2001 Galant Not Starting
Old Nov 3, 2011 | 05:34 PM
03222009's Avatar
Default 2001 Galant Not Starting
I have a 2001 Galant and it is not starting. It just clicks when the key is turned. We bought a new battery, a new starter and we had the alternator checked. We've also made sure all spark plugs are fine and checked the fuel pump as well. All of that is fine and it still does not want to turn on. It was fine last week and one morning I went to leave and it would not turn on not even with a jump. I am at a lost as to what else it can be. Any ideas?
Old Nov 11, 2011 | 08:39 PM
Galanthighspeeder's Avatar
Did you check for Codes?
Old Nov 21, 2011 | 08:53 PM
pen1137's Avatar
We have the same issue...it's at the shop now and they can't retrieve the codes and said it will have to go the the dealer (40 miles away, argh).
Old Nov 22, 2011 | 02:19 PM
03222009's Avatar
Yes, and the code was for the crankshaft position sensor. It was changed and the car still did not start. The code went away once it was changed but the next day it was back on and it came up the same code.
Old Nov 23, 2011 | 11:15 AM
Did you change the Cam Sensor?
If the Cam Sensor is bad it
wont let the engine start.
Old Mar 18, 2022 | 05:16 PM
IDK's Avatar
IDK
My car read same code {crankshaft sensor} so I change it and now I have no codes reading and I'm still unable to start it I'm confused myself..
Blazejben
May 14, 2012 03:59 AM
03222009
Nov 3, 2011 05:40 PM
stbrian
Nov 12, 2010 10:19 AM
nrendall
Jul 11, 2010 04:14 PM
JennJenn
May 21, 2010 10:41 PM
