2001 Galant v6
2001 Galant v6
Recently I had problem with water leaking to passenger side of car(quite a bit,too). Before I got it fixed my Infinity P913 started working intermittently, 1 speaker, then both speakers, had to input CODE, each time I started the car. The speakers would be very staticy then would clear up. Just before I got the a/c overflow fixed...the radio doesnt work at all. Can't even "power" it on. Can it be that my amp wiring or 'something' got wet and shorted out. HELP. Lonely without my SOUND
a/c evaporator case is clogged causing the overflow. need to get it unclogged. putting and air blower in the drain for 30 seconds usually works. if you have a factory radio, the amp for it is under the passengers front seat. i bet the a/c overflow got in the amp. seen it happen. amp not cheap either. good luck
