2001 Galant v6
Old 06-27-2010, 08:39 AM
COBBIE's Avatar
Angry 2001 Galant v6
Recently I had problem with water leaking to passenger side of car(quite a bit,too). Before I got it fixed my Infinity P913 started working intermittently, 1 speaker, then both speakers, had to input CODE, each time I started the car. The speakers would be very staticy then would clear up. Just before I got the a/c overflow fixed...the radio doesnt work at all. Can't even "power" it on. Can it be that my amp wiring or 'something' got wet and shorted out. HELP. Lonely without my SOUND
Old 07-05-2010, 11:22 PM
jgbrules's Avatar
a/c evaporator case is clogged causing the overflow. need to get it unclogged. putting and air blower in the drain for 30 seconds usually works. if you have a factory radio, the amp for it is under the passengers front seat. i bet the a/c overflow got in the amp. seen it happen. amp not cheap either. good luck
monkey714
08-03-2004 11:31 PM
HornersMits
08-01-2004 12:13 PM
b_bruton77
07-17-2004 02:56 PM
b_bruton77
06-23-2004 10:04 AM
b_bruton77
06-19-2004 03:28 PM
Quick Reply: 2001 Galant v6
