2002 Galant Climate Control
Old Jan 12, 2009 | 11:23 AM
jeffgolem's Avatar
Default 2002 Galant Climate Control
Has this happened to anyone else? At night with the lights on...if I try to twist turn the temp adjust leverl the light behind that lever only goes out...if it hit it on the side it goes back on. Is there a light bulb that can be replaced or do I have to swap out the entire Climate control unit?
Please, any advise on how to remove the bezel to get the climate control out without damaging anything or breaking unseen clips would be appreciated. Thanks!
Old Jan 15, 2009 | 09:33 AM
keith 1's Avatar
Default RE: 2002 Galant Climate Control
hi u have 4 bulbs behind the console the bulb what goes off and on is loose it just needs a twist i had the same trouble but on the other side of the console u no how to take the console out if not i will try to help
Old May 23, 2011 | 05:23 PM
TheGreenHornet's Avatar
Wow! haha I've been having the same problem. I'm glad it seems it's only a loose bulb instead of some faulty wiring. I just have to figure out how to access the far-left bulb (behind the hot/cold ****). The unit is currently on my lap.
bmerz
Feb 24, 2021 06:55 PM
JOE M
Nov 28, 2006 08:07 PM
fastblatt
Oct 3, 2006 07:39 PM
speedy
Feb 3, 2006 03:56 PM
FireDoc
Oct 13, 2005 06:07 PM
