2003 GTZ will not start
Old Sep 6, 2013 | 07:31 PM
Steve01's Avatar
Default 2003 GTZ will not start
2003 Galant GTZ with 120K miles.
Zero problems till now.
My daughter pulled into the parking space, turned off the engine, exited and locked the door. When she returned 30 minutes later, the car would not start.
It will crank okay, but when you release the key from the starter-engaging position, it sounds like it will almost start, then stops.
(Is there a fusable link? Or a fuse problem?)
So, when the starter is engaged, it seems like no fire is going to the spark plugs. When you release the starter, you may have fire for a second.
Tried the key in the door lock trick to reset it. No luck.
Checked the relays by swapping out engine ones with others. No luck.
Checked the fuses. None blown.
Bought a code checker. Zero Codes.
She has the oil and filter changed every 3,000 miles.
We are using a K&N airfilter and it is clean.
"Help me Obewan!"
Old Sep 6, 2013 | 08:24 PM
terminallance's Avatar
a few things it could be; fuel filter, fuel pump, injectors, timing, there could be others but these are the more likely.
Old Sep 7, 2013 | 09:08 PM
Steve01's Avatar
Thanks for responding, Terminallance.
Checked those. No problems.
Called wrecker and sent the car to my local mechanic.
I am just too busy to fix it.
I am changing my Escape hybrid front wheel bearings tomorrow (Sunday).
Funzy stuff. Not.
tacole27
Oct 5, 2011 05:55 PM
xaymi
Nov 20, 2009 04:23 PM
Los
Jan 5, 2007 11:20 AM
robgq24
Aug 11, 2005 07:23 PM
Elitepinky
Aug 10, 2005 04:45 AM
