2010 Galant Steering Wheel Rattle
Hi. My 2010 Galant has a steering wheel rattle that occurs when the car shimmers slightly (ac compressor on) or due to rough roads. It does this only in the spring and fall. When it's really hot or cold it doesn't do this as much. I have done some investigating and found that the noise seems to go away when I push down on the steering wheel slightly or move the tilt wheel lever below the steering wheel to a specific unlocked position. It appears that the mechanism which holds the tilt steering column in a given position is causing this noise. Has anyone experienced this? If so, were you able to fix it yourself or did the dealer fix it? Was it repairable at all? Thanks in advance for all responses.
