2010 Galant Steering Wheel Rattle
Old Nov 2, 2012 | 11:58 AM
Knight55's Avatar
Question 2010 Galant Steering Wheel Rattle
Hi. My 2010 Galant has a steering wheel rattle that occurs when the car shimmers slightly (ac compressor on) or due to rough roads. It does this only in the spring and fall. When it's really hot or cold it doesn't do this as much. I have done some investigating and found that the noise seems to go away when I push down on the steering wheel slightly or move the tilt wheel lever below the steering wheel to a specific unlocked position. It appears that the mechanism which holds the tilt steering column in a given position is causing this noise. Has anyone experienced this? If so, were you able to fix it yourself or did the dealer fix it? Was it repairable at all? Thanks in advance for all responses.
nativa
Jan 23, 2016 07:33 PM
Russk1978
Nov 23, 2010 11:45 AM
Knight55
Sep 22, 2010 08:52 PM
runner45
Oct 16, 2008 09:34 PM
lbc_rider
Apr 25, 2008 10:48 PM
