buzzer like sound + check engine light
Old Apr 24, 2009 | 02:50 PM
Galantcrnac's Avatar
Default buzzer like sound + check engine light
I drove on some rough road recently. ('99 Galant, 110k, 4cyl, 2.4L).
From vibrations ---- "buzzer like" screatching sound -- come from engine and for very short time check engine light appeared. Everything lasted ~10 sec.
Then everything went ok.
Autozone read no codes.
Few days latter, same thing happened...???!!!
Car runs perfectly afterward.
Does not sound like belt and belt related issues.
Old Apr 25, 2009 | 01:59 PM
Manybrews's Avatar
loose/corroded battery terminal.
or your batter isnt secured and its shorting on the hood, which will cause a fantastic fire/explosion.
Old Apr 25, 2009 | 02:19 PM
Blck3G's Avatar
well is the MIL-aka.(check engine light) still there? If so I suggest you try going somewhere that can look up this code...If you live near any community colleges with an automotive program they help many people out.
Secondly the vibration can be numerous things. Like Manybrews said it can be that which I hope it isnt.-That much Current rushing thruout the body of the vehicle may theoritically cause PCM malfunctions. So good luck trying to find out that MIL.
Old Apr 26, 2009 | 10:10 AM
It's not battery.
Check engine light just appears for few seconds, went to autozone, no codes.
It's dynamic sound.... when thing happened I immediately removed my foot of the acceleration pedal, car started to slow down,
and the sound changed down with rpm's.
But, all lasted to short to try to do more.
pgb205
Jun 4, 2009 10:40 PM
nexas8
Feb 19, 2009 02:27 AM
5star
Oct 23, 2007 09:58 AM
darylnj
Sep 21, 2007 06:02 PM
casualsax3
Dec 6, 2005 12:38 PM
