Car cut off on highway!!! Help!!
Sorry, it didn't post everything, 2.4L, cut off on highway no restart, has cam movement, has spark, fuel pump turns on, fuel reg isn't ruptured. Not even a burp. I checked around somemore on google and found there was a recall on a ckp sensor because wires were rubbing through and grounding out. I know the ckp works with the cam sensor by notifying #1 cylinder location. Which got me thinking that the injectors aren't firing. Would the engine still has ignition without the ckp in circuit? What do you think? Has anyone else had this problem? Thank you!
bronzebogen
13
04-16-2015 08:32 AM
pvtsmyser
09-12-2010 10:15 PM
