check engine light
Old Apr 19, 2009 | 08:40 PM
  #21
dsm1990gsx's Avatar
Originally Posted by 2shuvro
hi! back with the CEL codes. mine one is a 2001 galant VR-G. (plz see the first message)
the code is P0135-025 B1S1
i think this is something to do with the oxyzen sensor. please advice. Should i change? if no, then what can go wrong? If yes, then can anyone giveme the part's number so that i can order and replace.
Replace the o2 sensor, it should be the one on the front of the engine torwards the radiator.
Old Apr 19, 2009 | 08:41 PM
  #22
dsm1990gsx's Avatar
Originally Posted by fuadram
hey everybody,
As I saw, I have the best advisers over here, I decided to give the question in this section of the forum. I know is not related to check engine light. But, still is question. Does anyone know, if there is any rear (back) brake pads in Galant 2002 4 cylinder?
If there are pads in back brake system, then can you advise how to change them?
I appreciate your advice in advance.
You should be able to tell by looking at them. If you cant tell the difference between drums and disc brakes then let someone who knows check them.
Old Dec 23, 2009 | 03:38 PM
  #23
kingkingwolf's Avatar
Originally Posted by Sebba
Don't mention it! : ) It's what we're here for. Next time, just make another thread; it is easier to navigate.
You can do it yourself, it isn't all that hard. You will need a ratchet set, and some penetrating fluid like WD-40. Depending on how much rust there is, you might just need to break off the bolts.
Do NOT buy a catalytic converter from the dealership, unless you like paying $400 for something that would otherwise cost you a fraction of that. Get a generic one. The same goes for the o2 sensor.
The shaking almost certainly sounds like a mount.
It is really helpful.
I want to try it in my car.
Old Jan 22, 2010 | 02:44 PM
  #24
dmon67's Avatar
guyjg
Nov 13, 2021 03:27 PM
SpyderGST
Dec 27, 2014 06:50 PM
pgb205
Jun 4, 2009 10:40 PM
c577
Oct 16, 2007 12:03 AM
rkerner
Jul 22, 2005 01:04 PM
