Checking tranny fluid
Old May 22, 2021 | 01:27 PM
KZap's Avatar
Default Checking tranny fluid
I am not sure if my level is too high or not and if Im checking it right.
Bring to temp, shift through gears and leave in N then I check it. Fluid way up the stick. Ive tried taking someone out, still does it.
I dont know how much is in there! As long as I shift through gears levels way up stick.
Old May 22, 2021 | 09:46 PM
DibbyDibbyDJ's Avatar
If it is high up the stick then there is too much in it. If you wipe the stick, near the end you will maximum mark.
You are correct in your way of checking. Bring car up to normal running temp by driving. Select each gear for a couple of seconds then put in N or P and remove stick, wipe, and re insert for 5 seconds. Pull out and read level
red5001
22
Oct 22, 2022 11:40 AM
Deerpark
13
Nov 3, 2012 08:56 AM
aganthorp
Dec 23, 2009 06:25 PM
vess1
Feb 11, 2007 02:37 AM
mysterio2099
May 26, 2006 08:35 PM
