Engine Light
Old Nov 8, 2008 | 01:02 PM
yaofeng's Avatar
Default Engine Light
I inherited a 1998 Galant. The engine light is on with code P0301 and P0505. Googling shows #1 spark plug misfire and IAC problem. Advice please?
Old Nov 8, 2008 | 01:26 PM
dsm1990gsx's Avatar
Default RE: Engine Light
Changethe plugs and wires and clear the codes and see if the p0505 comes back on. If it does your probabaly looking at an iac valve.
Old Nov 12, 2008 | 06:17 AM
yaofeng's Avatar
Replaced the wire set and spark plugs. Nothing was changed. The check engine light is still on. I wanted to also replace the cap and rotor but the Autozone near me did not have them in stock. Does the Galant have mechanical timing? It is hard to belive it still exist in 1998.
What other parts should I throw at the car to get rid of the check engine light?
Old Nov 12, 2008 | 06:44 AM
dsm1990gsx's Avatar
Did you dissconnect the battery to turn off the cel?
Old Nov 12, 2008 | 11:34 AM
yaofeng's Avatar
No. I did not know that's required.
Old Nov 12, 2008 | 12:18 PM
dsm1990gsx's Avatar
ORIGINAL: yaofeng
Yeah you have to clear the light and see if it comes back on.
Old Dec 13, 2008 | 02:09 PM
yaofeng's Avatar
Sorry to follow up so late. Disconnecting the battery cleared the CEL and the car passed inspection. But soon after the CEL came back. I am just going to ignore it.
Old Dec 13, 2008 | 06:38 PM
dsm1990gsx's Avatar
Go to autozone and scan it, see if you have the same codes or not.
Old Dec 13, 2008 | 09:22 PM
Fkingiacmotor's Avatar
Hello, The iac needs to be changed. I guarentee it,those things go out very commonly.
If the idle is rough or going up and down then you know for sure.
guyjg
Nov 13, 2021 03:27 PM
shum_87
Aug 29, 2009 05:05 AM
pgb205
Jun 4, 2009 10:40 PM
EclipseFLAGirl
Nov 9, 2008 11:10 AM
serenabkhan
Nov 23, 2007 05:44 PM
