G/f's galant.
Old Jun 21, 2010 | 07:46 PM
940guy's Avatar
Default G/f's galant.
Hello, all
I like to start of by introducing my self as 940guy. Im a complete stranger to these car. Im and Straight up volvo guy
HEY! everyone has there passion for cars. this is mine at 15psi chipped.
Yea that it is but anyways...
The A/c drain on my Girl friends car is leaking into the passenger side flood board I have looked around and found this is a common problem.
My question is today had it up on the lift and could not find the drain for it at all. Any images of were said drain is to unclog?
Old Jun 21, 2010 | 09:20 PM
Heater core. Mitsubishi's have crappy ones.
Old Jun 21, 2010 | 09:33 PM
940guy's Avatar
Then why would this be pure water. No coolant
Old Jun 27, 2010 | 10:01 PM
elhombre923's Avatar
I have the same problem. I'm a VW guy, my girlfriend has a 2001 Galant and when she turns on the A/C water leaks into the passenger side. I read up on the problem, but does anybody have some pictures. I'm going to lift it up this coming weekend to try to fix it. Any help will be greatly appreciated.
Old Jul 5, 2010 | 11:35 PM
jgbrules's Avatar
the drain is almost directly behind the motor mount on the backside of the engine. slightly covered up by the isulation on the firewall. put air pressure to the drain and it will unclog
Old Jul 13, 2010 | 12:31 AM
Van's Avatar
Van
You're probably gonna want to pull the evap box out from behind the dash and clean out the debris inside that is clogging the drain tube. You might get some of it out from the side, but not all of it.
BTW, I've never seen a Mitsu heater core fail. Only the small gasket on the Diamante.
Last edited by Van; Jul 13, 2010 at 12:33 AM. Reason: add response to silly heater core comment above
butter03
Jan 16, 2006 02:57 AM
DAVEMOTOR
Jan 4, 2006 06:25 PM
BigSteve0034
May 20, 2005 02:42 PM
