View Poll Results: to get to start
help to start
0%
help to start
0%
Voters: 0. You may not vote on this poll
help
is it a 2.4 or a 3.0 engine??? and are you sure the marks line up?? are you sure the blade behind the crank gear is on correctly?? are you sure its not on backwards???? are you sure the cam gear(s) is lined up???? are you sure you didnt put the crank sensor on backwards?????? are you sure the crank sensor was the problem??? seen ALOT of cam sensors go bad on the 2.4L galant. just sayin!!!!
