Help! I did a real stupid thing
I was hooking up a remote starter on my 2001 galant and by accident i touched the 12 volt constant with a screwdriver and hit metal causing a spark and now i can't start my car! I do not get a crank, horn works, lights work, radio does not work. I checked all fuses, all fine. Any help i would soo apreciate it. I hope its something stupid and nothing major.
RE: Help! I did a real stupid thing
I would double check your fuses and fusible links.
and make sure you dont have a short in the wire...accidently did somthin and caused a spark on his reading lamp and caused a bit of a short.. i fixed it it was just a small streatch of wire so it was easy for me to fix
any help on location of fusible links on a 2001 galant,and also is there any way to check the relays
The fusible links should bein the battery junction box or under the dash w/ the fuses, I 'm not too sure abt galants. To check a relay just try swaping it w/ a know good relay like fog lights and such.
