Help! I did a real stupid thing
Old Nov 18, 2007 | 01:02 PM
tul813's Avatar
Default Help! I did a real stupid thing
I was hooking up a remote starter on my 2001 galant and by accident i touched the 12 volt constant with a screwdriver and hit metal causing a spark and now i can't start my car! I do not get a crank, horn works, lights work, radio does not work. I checked all fuses, all fine. Any help i would soo apreciate it. I hope its something stupid and nothing major.
Old Nov 18, 2007 | 04:55 PM
dsm1990gsx's Avatar
Default RE: Help! I did a real stupid thing
I would double check your fuses and fusible links.
Old Nov 18, 2007 | 05:07 PM
jpmontero98's Avatar
and make sure you dont have a short in the wire...accidently did somthin and caused a spark on his reading lamp and caused a bit of a short.. i fixed it it was just a small streatch of wire so it was easy for me to fix
Old Nov 18, 2007 | 08:45 PM
tul813's Avatar
any help on location of fusible links on a 2001 galant,and also is there any way to check the relays
Old Nov 18, 2007 | 08:58 PM
dsm1990gsx's Avatar
The fusible links should bein the battery junction box or under the dash w/ the fuses, I 'm not too sure abt galants. To check a relay just try swaping it w/ a know good relay like fog lights and such.
RCJr9186
Feb 14, 2008 08:20 PM
lucasmarine
23
Nov 4, 2007 10:02 AM
WhiteTrash93
1st Generation
18
May 22, 2006 12:46 AM
truckin
Oct 23, 2005 03:04 PM
