My Galant is a battery killer... Sick and Tired
Old Feb 22, 2010 | 02:40 PM
lindy8_man's Avatar
Default My Galant is a battery killer... Sick and Tired
Let's see... I bought a 2000 Galant ES in 2002. Now has 179K It has been great with one exception... Every 1.5 years (because it's metric) I have to replace the battery. The car runs perfect once replaced, I have check the alternator (using the negative cable, and still runs method). The electrical system passes with flying colors every time. Checked the pos battery cable/terminal with multimeter when the car was off, and I'm not getting excessive amperage there. I have had no problems with the starter, or other relays (all original).
Old Feb 22, 2010 | 03:32 PM
dsm1990gsx's Avatar
Does the car sit around alot?
Old Feb 22, 2010 | 05:03 PM
lindy8_man's Avatar
No, I drive it almost every day. The battery quits very suddenly, and no amount of re-charging will bring it back.
Old Feb 23, 2010 | 05:49 PM
lindy8_man's Avatar
Hmm, Interesting points. The only modification I have made is the K&N filter charger. Everything else is stock. ie. No DVD or any extras. In a given year I put on about 12K I have freeway driving one direction that is about 15 miles, with a mile of stop and go on each end. In that freeway driving I typically drive between 75 and 80 (San Diego Standard highway speed).
Now you brought up two interesting prospects. My remote keyless fob quit working about 9 months ago. Never bothered to mess with it. I just use the key. The car was killing batteries before that system failed...
The AC control module... How do I check that?
Old Feb 25, 2010 | 05:26 AM
trainy's Avatar
If it improperly wired...and will eat batteries..and yes it can be intermittant...also had one more question...that is how far do you drive it in a years time?......is it all stop and go? short trips? long trips? alot of idle time
dragonlancer
Sep 3, 2007 11:49 PM
soundcolor
Mar 19, 2007 11:17 PM
slow420a
Apr 8, 2006 04:46 PM
Eclipse_GSX
Jul 10, 2003 02:34 PM
