Squeaking sound when AC/Heat turned on
Old Dec 7, 2011 | 02:07 PM
hamilton456's Avatar
Question Squeaking sound when AC/Heat turned on
A squeaking sound has started, it only happens when I turn on the AC/Heat. It squeaks faster if I crank up the dial. It does not vary in speed with the speed I am driving. It does, however, vary on it's own occasionally. It sounds like a sad belt or sometimes a sad motor.
What is the problem and how much should it cost to fix? 2006 Mitsubishi Galant 6 cyl
Old Dec 7, 2011 | 02:08 PM
Also, if it could be more than one thing, how do I isolate it down to one thing so I can get pricing information? Thanks in advance for your help. -hamilton456
Old Dec 8, 2011 | 05:07 AM
BrandoSr's Avatar
Default 98 Galant
I got the same EXACT problem...defrost/heater...squeal...? What is it, I've tightened the belt too tight, retightened looser, then back...cant seem to stop it, it didn't do it off the showroom floor so what has to be replaced! I've been told idler pulley, and told alternator...cant be both
Old Dec 22, 2011 | 05:50 PM
Galanthighspeeder's Avatar
I had the same problem with my car.. my A/C compressor
clutch pulley was worn out, I replaced it, the sqealing noises
went away.
Old Dec 22, 2011 | 08:20 PM
_93TSI_370+K_'s Avatar
Do I HATE this stupid site that times me out within minutes!!!! I may go to another DSM...I'll try to duplicate my response.
What dial do you turn up? If it is for the fan speed and the squeaking gets faster, it is the fan motor. If the squeaking increases with engine speed, it is a belt/idler or the accessory that is being driven by the belt. Try to loosen or remove the belts one by one, restart the car for a short time to see if the noise stopped. Continue doing this until the squeaking stops and you have identified the source,
spccortez
Dec 18, 2008 04:36 PM
charioteer
4th Generation
Jan 7, 2008 11:34 AM
nakhshab
Jun 29, 2005 04:16 AM
nakhshab
Jun 11, 2005 03:27 PM
bcolins
Jan 31, 2005 03:11 PM
