Timing belt change..when?
I have 60k miles on my 1999 Mitsubishi Galant V6, I'm just wondering when I would need to do the timing belt change at? Would 100k be stretching too far?</P>
thanks</P><edited><editID>galant4eva</editID><editDate>37985.7228587963</editDate></edited>
thanks</P>
Depends I have heared that the Cali spec Galant will need to be changed at 60,000 but the Fed spec Galant your ok until 100,000</P>
Im sorry, but what does Fed stand for?</P>
Also, anybody on here knows when i'm suppose to change the timing belt?</P>
thanks</P>
Fed stands for a Federal Spec Galant. If your not in California then you most likely have a Federal Spec Galant which should say in your owners manual (check it) that you will not need to change it for 100,000 miles. I havea California spec Galant so I can't be 100% sure on this butmost my friends at www.galantforms.com have Federal Spec Galants. So joing the board and ask away I am sure that someone there can give you a 100% for sure answer. In my opnion I would go ahead and do it at 60,000 just to be safe. Well good luck and hopefuly I will see you on www.galantforms.com </P>
Thanks for the quick response!
I have a Cal spec Galant too. I tried to go to the link you gave me, but it doesn't seem to work. I thought you might have spelled the link wrong, so I even tried www.galantforums.com, but it didn't work either.</P>
</P>
Nevermind, it works now<IMG src=smileys/smiley1.gif border="0"></P><edited><editID>galant4eva</editID><editDate>37986.5952546296</editDate></edited>
</P>
lol your right I spelled it form not forum. I see you just joined welcome to the family and happy modding.</P>
jneumann
12-20-2005 05:39 AM
