Vibration when starting car
i have 2001 galant and i been having this problem for several months. when car is in drive gear or reverse gear i get alot of vibration and a knocking noise from the lower front, if i put car in park or neutral vibrationa and noise stops. its the worst when car is cold in themornings. do yall know wat might because the problem thanks.....
RE: Vibration when starting car
Does it clunk when you shift from reverse to drive or vise versa? Sounds like a bad engine/trans mount.
^^ what he said. if the noise if only present when changing from park to nuetral or reverse or drive then its a high likely hood it is 1 or more mounts
its definately your roll mounts probally run you 100 dollars for the both of them
