Vibration when starting car
Old Mar 20, 2008 | 08:47 PM
galant2001's Avatar
Default Vibration when starting car
i have 2001 galant and i been having this problem for several months. when car is in drive gear or reverse gear i get alot of vibration and a knocking noise from the lower front, if i put car in park or neutral vibrationa and noise stops. its the worst when car is cold in themornings. do yall know wat might because the problem thanks.....
Old Mar 21, 2008 | 09:08 AM
dsm1990gsx's Avatar
Default RE: Vibration when starting car
Does it clunk when you shift from reverse to drive or vise versa? Sounds like a bad engine/trans mount.
Old Mar 21, 2008 | 12:56 PM
blk n tan's Avatar
^^ what he said. if the noise if only present when changing from park to nuetral or reverse or drive then its a high likely hood it is 1 or more mounts
Old Apr 4, 2008 | 01:50 AM
silversurfer's Avatar
its definately your roll mounts probally run you 100 dollars for the both of them
jdohe
May 3, 2020 03:54 PM
galant2001
Nov 13, 2007 06:52 AM
spyder4g63t
Nov 12, 2007 10:20 PM
matt02708
May 11, 2007 10:18 PM
