'02 Lancer OZ Warm-up catalytic converter meltdown
Old Feb 4, 2009 | 10:37 AM
mwolverine89's Avatar
Default '02 Lancer OZ Warm-up catalytic converter meltdown
I have a 2002 Lancer OZ rally edition. my Service engine soon light is on. its for a TSB emr-05-001r2, pcm update for warm-upcatalytic converter meltdown, which was a recall in '05. which i had fixed. does anyone know what part i would need to replace and where i can get it, the dealer wont tell me what part it is and as far as i know they are the only place i can get it. its one of 2 sensors one is $860 and the other is $680. if anyone could help id love to be able to get the parts without having to pay a few thousand dollars in parts and labor.
Old Feb 4, 2009 | 11:35 AM
dsm1990gsx's Avatar
Default RE: '02 Lancer OZ Warm-up catalytic converter meltdown
What code are you getting? If its po420 cat efficiancy below threshold you'll most likly need a cat assembly.
Old Feb 4, 2009 | 11:55 PM
the code that came up is a tech service bulletin: EMR-05-001R2WARM-UP CATALYTIC CONVERTER MELTDOWN
Old Feb 5, 2009 | 04:08 PM
Manybrews's Avatar
its under recall if you have less than 100k.
Old Feb 7, 2009 | 05:35 AM
My car doesnt quailify for the racall, it was not manufactured within certain dates, pluse the recall was for a pcm upgrade which was done on my car back in 2005
Old Feb 7, 2009 | 07:19 AM
dsm1990gsx's Avatar
Replace your cat its covered under 8 years or 80k miles.
Old Feb 7, 2009 | 07:26 AM
Manybrews's Avatar
Yes, your car does qualify for the recall. The PCM update was to prevent cat failure. But yours failed, and as such needs to be replaced. Which it will under recall if youre under 100K miles.
If youre out, then its your cost.
Old Feb 22, 2013 | 10:14 AM
rickb928's Avatar
I just bought an '04 OZ, 212k, and just popped a P0420 for a few days. I'll check the O2 sensors, but I expect I'll be buying a front cat. I see these for <$300, which is livable.
And the OZ has a splendid Arizona body, nearly flawless, interior is good, other issues manageable, I bought it cheap. Certainly a lot easier to deal with than the Saab I had, trust me. I'll be peppering you guys with questions for a while, so thanks in advance for your patience.
Old Mar 24, 2013 | 06:03 AM
scottz123's Avatar
How do you check the O2 sensors? Where do you find cats for less than $300?
Thanks
Old Mar 25, 2013 | 06:48 AM
rickb928's Avatar
Default $300 cats
Some eBay vendors look legit. Lots of web sites with cats around $270.
I'll be checking O2 sensor voltages, and I May try the rear O2 spacer trick just to see. That is in a thread here somewhere.
