Does the indicator area say anything specific?
Have you tried pulling out your key and actually trying to start the car with the physical key? |
Key turn hard - The key hole NEEDS WD40
spray the key with wd4o and wipe it. do not put wd40 on the key hole just on the car key. I have the same problem before. You just have to STEP ON THE CLUTCH ALL THE WAY TO THE FLOOR. It will NOT start if the clutch is not all the way to floor. MIVEC engine performs better if the engine is warm up. So in the morning when you first start your car WAIT UNTIL THE RPM is on 1000 rpm IDLE and then you can drive your car. do that when you first start your car in the morning. |
