2004 Lancer
Old Dec 17, 2013 | 08:26 PM
ivopivo's Avatar
Default 2004 Lancer idle issue please help...
I have an issue with my 04 Lancer when turning on, especially in the cold weather. When it turns over and starts, the RPM shoot up as normal to 1.5-2k, then back down, but it goes too far down and the car turns off. Seems like whatever is supposed to be holding it "up" at idle is not doing so and the car turns off. Giving it a little gas right after turning on, simply to keep the RPM up above 500-700, will make the car stay on. You need to give it gas for about 3-5 seconds or so and it idles fine then. So far I've replaced the valve cover gasket, spark plugs, wires and checked timing belt which looks ok. Any advice would be greatly appreciated, even to just point me in the right direction on where/at what to look. Thanks in advance.
Old Dec 22, 2013 | 09:00 PM
ivopivo's Avatar
Oh and this is more prominent in the cold, whereas when it's warmer out most of the time it turns on just fine.
Old Dec 29, 2013 | 10:48 AM
Thahomeboyb's Avatar
Check all your fluids . Starting fluid etc.
And check your coolant . Hopefully none of you fluids freezing .
Old Dec 29, 2013 | 12:30 PM
Akzle's Avatar
sounds like a ghey sensor.
MAF, thermo, TB, knock, something. i always advise an ECU reset.
Patrick
Oct 26, 2011 03:21 PM
seco007
Feb 16, 2006 01:16 PM
seco007
Jul 28, 2005 11:00 PM
Byker_Audi
Jan 31, 2005 02:30 PM
mmarino
Jun 17, 2004 02:59 AM
