2015 Lancer EX 1.6 Engine not cranking (no symptoms)
I am having problem with my 2015 lancer EX 1.6 engine not cranking. There are no symptoms prior to this issue. It just came one day after I park overnight and engine wont crank. I have check the fuses, battery, and starter are all working good. I try to start the engine by putting power to the starter solenoid with the ignition 'on'. The engine crank and rotate but the engine wont run. I checked the starter relay and found no power coming to energize the relay coil during cranking. Any similar issue like this and have fixed would be great help.
I don't know anything about your specific vehicle, but often this is due to the security system of a car not detecting the security chip in your key. In many cars this is done with a detecting ring around the ignition switch. Also, google's your friend--a quick search gave me three Youtube videos, and a possible fuel pump relay failure. Good luck.
Thank you for your feedback. The remote key seems to be working fine as I have able to lock and unlock the door. Anyway I will have it check to make sure it is working fine as I am suspicious with the remote as well. I have check the fuel pump relay and it’s coil is energized when switched to ignition on. I even swap relay to known good one. I think fuel pump system seems to be working okay. |
