2015 Lancer EX 1.6 Engine not cranking (no symptoms)
Old Mar 6, 2019 | 12:59 AM
renskys26@yahoo.com's Avatar
Exclamation 2015 Lancer EX 1.6 Engine not cranking (no symptoms)
I am having problem with my 2015 lancer EX 1.6 engine not cranking. There are no symptoms prior to this issue. It just came one day after I park overnight and engine wont crank. I have check the fuses, battery, and starter are all working good. I try to start the engine by putting power to the starter solenoid with the ignition 'on'. The engine crank and rotate but the engine wont run. I checked the starter relay and found no power coming to energize the relay coil during cranking. Any similar issue like this and have fixed would be great help.
Old Mar 6, 2019 | 07:17 AM
jburney's Avatar
I don't know anything about your specific vehicle, but often this is due to the security system of a car not detecting the security chip in your key. In many cars this is done with a detecting ring around the ignition switch. Also, google's your friend--a quick search gave me three Youtube videos, and a possible fuel pump relay failure. Good luck.
Old Mar 6, 2019 | 01:50 PM
Thank you for your feedback. The remote key seems to be working fine as I have able to lock and unlock the door. Anyway I will have it check to make sure it is working fine as I am suspicious with the remote as well. I have check the fuel pump relay and it’s coil is energized when switched to ignition on. I even swap relay to known good one. I think fuel pump system seems to be working okay.
dunnerstall
Dec 5, 2015 09:09 AM
WxDarklingxW
Nov 16, 2012 07:57 AM
Scubba.steve
Oct 11, 2008 01:11 PM
gs_dirtdog
Jan 11, 2007 10:45 PM
irdefector
Jul 6, 2006 07:23 PM
