AC button led not working
Old May 23, 2009 | 03:11 PM
fantomasz's Avatar
Default AC button led not working
AC button led don't light up when I press ac button.How to fix it?I must replace whole unit?
It's small white led bud don't know what type of led is that.
03 lancer es
Old May 23, 2009 | 05:16 PM
BrokeDad's Avatar
Have you checked the A/C fuse in the engine compartment fuse block ? Is the A/C working and just the LED not ? Need more info.
Old May 23, 2009 | 07:46 PM
fantomasz's Avatar
just led , ac is working
I already take apart control unit and it's small white led
Old May 23, 2009 | 08:23 PM
BrokeDad's Avatar
It's most likely then a bad connection or switch contact to the LED. I work in repairing electronics. The A/C LED in my spyder is a tricolor although they don't use the red mode. Yellow is A/C off .. Green is A/C on. I'm not up on what LED type is used in your model. LED's almost never burn out although it is a remote possibility.
I'd recommend not fixing it if it is just a cosmetic issue unless it bugs you so much and you have the cash to spare. Perhaps you could find a used assembly also. I've seen this link posted for searching junkyards by the moderators:
www.car-parts.com
Have a great holiday weekend.
BD
theiss2200
Sep 12, 2019 08:07 PM
mastersak
Mar 24, 2015 06:07 AM
OCdreamin30
Jul 22, 2010 06:28 PM
Tariq777
Oct 23, 2009 10:31 AM
arshem
Sep 3, 2008 05:27 PM
