Adding a sub to the 09 Lancer
Old May 6, 2009 | 05:06 PM
Paul L's Avatar
Default Adding a sub to the 09 Lancer
Just got a 09 Lancer GT that come with the Fosgate system. I have a really good sub and sub-amp left over from last car. I am wondering how I can wire the sub-amp to the fosgate. Tried to search for FSM but no luck. Is there any connection in the trunk that I can use instead of taking out the head unit from the dash?
Thanks.
Old May 10, 2009 | 09:31 PM
guido28's Avatar
If you are going to leave the head unit as is AND the Fosgate "AMP" under the driver seat then you will have to get pro help I dont think you can keep the stock amp and piggyback another amp to it. The way I did it was eliminate Fosgate "AMP" use a JL-Audio Cleansweep to eliminate the sound processing of the head unit THEN you can use your amp with new sub. Also REMOVE the old sub ASAP because it is a 1 ohm sub and it will BLOW rather quickly when powered by new amp. Trust me..hehe.
Old May 11, 2009 | 04:17 PM
Paul L's Avatar
guido28,
Thanks for the reply. That Fosgate amp must be quite an amp since it can drive the 1 ohm sub. I am hoping the amp is hiding in the trunk so that I can split the RCA signal from the head-unit by a Y-splitter to the Fosgate amp and the extra amp, running the stock amp/sub and the addition amp/sub in parallel.
jay0sun
Jul 1, 2025 12:45 PM
Lancer06
May 2, 2012 04:44 PM
benjaminws
Jul 20, 2009 09:39 PM
ERIC1006
Sep 30, 2008 06:26 PM
lancerOZ
Jun 28, 2006 06:46 PM
