Apple iPhone connection problem
Hi,
I have an Apple iPhone and using it with my 2008 Lancer GTS Bluetooth Hansfree System (no Navi). The phone pairs with car's system fine and works fine too. The problem is, the phone keeps disconnecting from the handsfree system. And I have to turn off the car and restart it to reconnect. Anyone esle experiencing the same problem? |
RE: Apple iPhone connection problem
ORIGINAL: nmkavadarli Hi, I have an Apple iPhone and using it with my 2008 Lancer GTS Bluetooth Hansfree System (no Navi). The phone pairs with car's system fine and works fine too. The problem is, the phone keeps disconnecting from the handsfree system. And I have to turn off the car and restart it to reconnect. Anyone esle experiencing the same problem? By the way I have a 2008 Lancer GTS with sun and sound package and navi. |
I can confirm that this happens with my iphone also.
Strangely, for the first few weeks I had my iphone, operation with my car was seamless all the time. Now, I find that after placing or receiving either one or two calls from inside my car, my iphone will spontaneously disconnect from the bluetooth handsfree system. From there, I have to re-start my car to get it back. On several occasions the phone has magically re-connected when I've received calls later, but generally a restart is required. I've tried nailing down some kind of pattern, but so far it just seems that after the second call (incoming or outgoing) that's it, disconnect. It's not a timer built into the iphone, because if I place two calls in the first 5 minutes my car is running, the thing will disconnect. |
| All times are GMT -5. The time now is 07:44 AM. |
