Cvt question
Old May 16, 2025 | 05:38 PM
Mikeavery86's Avatar
Default Cvt question
I have a 2009 lancer 2.4 transmission went out so I replaced it with a known good spare I had but it doesn’t seem right, almost like the transmission is slipping. I swapped the electronics from the valve body so it wouldn’t throw any codes. Does this need a relearn or calibration when installing a new transmission?
Old May 19, 2025 | 03:30 PM
SRTx's Avatar
Hello, is the same transmission? Did u change fluids, filters, torque converter. Any codes? Check pressures
Old May 19, 2025 | 04:18 PM
same model transmission from a donor car of the same year and model. Donor car had 90k on it and had body damage so I took the transmission and engine for a spare in case. New filters, Mitsubishi genuine j4 fluid and same torque converter that was in the 90k transmission. I changed the eeprom that was in my original transmission to avoid having to reprogram anything. No codes and sounds like everything is fine. I’ve rebuilt many automatic transmission but I have yet to deal with a cvt until now.
Old May 19, 2025 | 08:23 PM
SRTx's Avatar
That’s good. I’m not an expert on CVT but from repairs I made; it was a pressure solenoid, was giving me rough shift and slipping. No codes at all… I had to drive it couples of times, reading pressures. And compare with a good CVT….Had to say, CVT isn’t a science but gives a really good headache sometimes.
Almost forgot, reset the computer.
Old May 19, 2025 | 09:41 PM
maybe it’s a solenoid just not sure why it worked perfectly when I pulled it to give issues now that I installed into a different vehicle. I ordered the mut 3 scan tool to reset some of the learned values of the cvt to see if that helps. Hopefully someone with experience will chime in and give some insight. Thanks
Kwizz
Feb 6, 2022 09:15 AM
Homer1959
Nov 21, 2021 01:03 PM
Kaba Konate
Sep 9, 2020 01:23 PM
Barli
Aug 19, 2015 07:02 PM
