ECM-problem ?
Old May 23, 2005 | 06:37 PM
borsno's Avatar
Default ECM-problem ?
Don´t know if this the correct place for this question ....anyhow
Any good suggestions for treatment of my MB Lancer 1,8 GTI with following apperance:
- after the engine have beeen working proparly and beeing stopped, trying to start again, starter-motor running ok , but the engine running temporary on 2-3 cylinders. Only way to get it running is to remove the terminalconnection on the battery for a while and then connect and operate the ignition-key. Then it´s working ok until it´s switched off and you try starting again .
Seems that the powerbreak resets the electronicsystem . Is this an indication that the ECM-module is not working ok ? Fairly expensive unit so any other possible step recommended ?
If replacing the ECM , would a unit with code E2T33480A work ok replacing the existing with code
E2T35878 ?.
Old May 31, 2005 | 12:51 AM
crunchie's Avatar
Default RE: ECM-problem ?
Why not pick up an ECM from a salvage yard or even online store? Probably half the price (or less) compared to dealers/retailers. Doesn't take much to install anyway.
David G Mcallister
Feb 5, 2015 05:26 PM
bdmartin
Apr 19, 2007 05:34 AM
reggieccrgto
Oct 31, 2006 08:41 PM
hoosierdaddy_87
Jul 5, 2006 09:28 PM
cooley
Apr 2, 2004 03:03 PM
