Mitsubishi Lancer saloon 2008 DID 2.0 diesel help
Old 03-02-2018, 01:00 PM
Lucylancer09's Avatar
Default Mitsubishi Lancer saloon 2009 DID 2.0 diesel help
Hi guys,
I am new here but I need of desperate help!
I have a 2009 lancer 2.0 DI-D saloon gs4 with 160k on the clock always started and run fine with no issues at all untill recently a few weeks back the car began to splutter and loose and gain power between 2000rpm and above mainly in 3rd gear and upward I thought that because I had been using supermarket fuel it had maybe clogged the fuel filter however the car then began to struggle to start as well as the power lose and spluttering issue I have had the cam belt water pump and auxiliary belt changed 2 weeks ago ( problem was there before belt change etc ) anyway the other day I was driving and the car lost all power and cut out completely ! Since then I have changed the fuel filter battery and air filter and recently had new oil put in all levels are fine I plugged it in and an error
code appeared saying turbo underboost and ABS speed sensor faulty and something about my EGR and the car will not start at all not even using QuickStart directly into the throttle body ! Any idea what’s caused this issue with the power and spluttering and how I can fix it ? And any ideas why it now will not start at all ?
Thanks In advance
Daryl
recalcitrant mule
06-08-2017 05:15 AM
Lee Smith
12-30-2016 02:50 AM
DGreer
01-02-2015 08:46 AM
666elpedro
08-04-2013 09:36 AM
rjc1955
08-17-2010 06:06 AM
Quick Reply: Mitsubishi Lancer saloon 2008 DID 2.0 diesel help
