Lancer 2010 intermitten stalling and rev drop
Old Jul 15, 2021 | 12:50 PM
krisz's Avatar
Default Lancer 2010 intermittent stalling and rev drop
Hello everyone, I have a 2010 1.5 petrol 4A91 Mitsubishi Lancer. When I press the clutch the engine rpm drops below 500 and in cold weather the engine dies. Sometimes everything is allright. Please see the attached video.
We have changed all sensors, the throttle body and injector rail from a same type of Lancer without any luck. The other car works perfectly. The car got new spark plugs and engine flush and fuel system cleaner. 4 garages were checking the car without fixing it.
The compression is 155psi in cylinder 1,2 and 4, but 115 in cylinder 3. I think if the compression would be the problem then the fault should happen all the time but it is an intermittent thing.
Any idea would be greatly appreciated.
Update: the intake manifold pressure is 44 kpa at idle, the other Lancer has 30 kpa.
File Type: avi
krisz
Jul 14, 2021 12:45 PM
OutlanderCanada
May 13, 2019 10:31 AM
dmdm
Mar 25, 2010 02:12 AM
dmdm
Mar 25, 2010 02:06 AM
hektorsky
Jan 26, 2010 05:28 AM
