MMCS navigation Maps replacement Guide
1 Attachment(s)
Hey Guys,
i have a 2009 Lancer GTS. got it for less then a week. and ive been searching like crazy on ways to replace the maps. i have read countless of guides and instructions but none were clear. so after i figured it out i decided to write this mini guide for those of you that have the same problem. so... first, some basic facts: 1. you cant upgrade the maps unless you buy it legit with a 1 time use unique version key up (or so we thought) 2. the maps cost between 180-220$. 3. there is an update once 1.5 years. what you will need. 1. take ur HDD out by following the instructions on page 2 here: Some fun with the MMCS display - Page 2 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums 2. hack your HDD (follow these guide, the first page pretty much explain it all its much simpler then it looks like: https://mitsubishiforum.com/forum/mi...ck-mmcs-25583/ 3. Find online or from a friend the latest map update (available online for the EU maps, impossible to find online for the US maps (yet). 4. when you get the CD (off the internet or a friend or wherever) you will see a set of files within that dVD: here is the list of files: Code:
ALLDATA.KWI 6. download the attached zip file (script) i provided, extract it and dump it in the same folder where you copied all the files. 7. Run the script. 8. now you will have all the HD1.*** set of files in an ordered number HD1.001 - HD1.641. 9. download the program 7zip (can be downloaded from: 7-Zip (unless you already have it). 10. Highlight all of the HD1.001 --> HD1.641 files. 11. Right click (or use any way you want basically) and extract them all to a different location (for organization purposes only). 12. You will get a Big almost 20GB file named Code:
HD1~ 14. You will now have these set of files: Code:
Folder named IDX 16. You will see a couple of HDD partitions. 17. Easiest way is to simply find the partition that contain the exact same files as written in steo 14. 18. Make your self a copy of the files on the MMCS original HDD for backup. 19. Delete all the files and then replace with the files you got from step 13/14. 20. Disconnect the HDD from your computer. 21. Re-install it back in your car and that's it. you are now with new updated maps. hope this help, good luck!! |
hey man, do you know if 2013 maps for the US are available? if so, how can i acquire them for free??? thanks man!
I am looking for 2013 European Maps.
