MMCS navigation Maps replacement Guide
Old Aug 29, 2012 | 06:18 PM
M.a.S.e's Avatar
Post MMCS navigation Maps replacement Guide
Hey Guys,
i have a 2009 Lancer GTS.
got it for less then a week.
and ive been searching like crazy on ways to replace the maps.
i have read countless of guides and instructions but none were clear.
so after i figured it out i decided to write this mini guide for those of you that have the same problem.
so...
first, some basic facts:
1. you cant upgrade the maps unless you buy it legit with a 1 time use unique version key up (or so we thought)
2. the maps cost between 180-220$.
3. there is an update once 1.5 years.
what you will need.
1. take ur HDD out by following the instructions on page 2 here:
Some fun with the MMCS display - Page 2 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
2. hack your HDD (follow these guide, the first page pretty much explain it all its much simpler then it looks like:
https://mitsubishiforum.com/forum/mi...ck-mmcs-25583/
3. Find online or from a friend the latest map update (available online for the EU maps, impossible to find online for the US maps (yet).
4. when you get the CD (off the internet or a friend or wherever) you will see a set of files within that dVD:
here is the list of files:
Code:
ALLDATA.KWI
CANB120.CBX
CDDS*.TXT
ECDDB.UDT
ECDDB.UDX
HD1.*** (164 FILES)
INDEX.TXT
LOADING.KWI
MY.INI
NR216UM.SCE
SUBCPU.ME
5. Copy all files to your local hard drive (if on a DVD).
6. download the attached zip file (script) i provided, extract it and dump it in the same folder where you copied all the files.
7. Run the script.
8. now you will have all the HD1.*** set of files in an ordered number HD1.001 - HD1.641.
9. download the program 7zip (can be downloaded from: 7-Zip (unless you already have it).
10. Highlight all of the HD1.001 --> HD1.641 files.
11. Right click (or use any way you want basically) and extract them all to a different location (for organization purposes only).
12. You will get a Big almost 20GB file named
Code:
HD1~
13. Once again using 7zip take this file and extract it (again) to a different location (again, for organization purposes only).
14. You will now have these set of files:
Code:
Folder named IDX
0.1
0.2
ALLDATA.KWI
CTRYMETA.CSV
INDEXDAT.KWI
PAR_MNG.ME
PARAM2.ME
PARCEL.KWI
REGION.KWI
TMCINFO.ME
VOICE001.ME
VOICE002.ME
15. If you finished the instructions to unlock your HDD, now is the time to connect the MMCS HDD to your computer.
16. You will see a couple of HDD partitions.
17. Easiest way is to simply find the partition that contain the exact same files as written in steo 14.
18. Make your self a copy of the files on the MMCS original HDD for backup.
19. Delete all the files and then replace with the files you got from step 13/14.
20. Disconnect the HDD from your computer.
21. Re-install it back in your car and that's it.
you are now with new updated maps.
hope this help, good luck!!
File Type: zip
Old May 8, 2013 | 12:57 PM
CMS062407's Avatar
hey man, do you know if 2013 maps for the US are available? if so, how can i acquire them for free??? thanks man!
Old Aug 18, 2013 | 03:59 AM
jsubiros's Avatar
I am looking for 2013 European Maps.
doctorC
Apr 10, 2015 06:31 AM
antonyvijai
May 9, 2010 12:58 AM
geohal
May 8, 2010 01:50 AM
xhomm02
Sep 15, 2008 09:25 AM
xhomm02
Sep 9, 2008 01:32 PM
