A question about engine size on '04 Sportback
Old Mar 5, 2006 | 01:30 PM
mphil804's Avatar
Default A question about engine size on '04 Sportback
When I went to the dealer, he said the engine in his '04 Sportback LS was a 2.0 liter. However, online, it's often listed as a 2.4 that's available. Is there any way I can be sure which it really is? It'd be nice to know and I'm not sure which to believe. Thanks!
Old Mar 6, 2006 | 02:18 AM
wicked_outlander's Avatar
Default RE: A question about engine size on '04 Sportback
its a 2.4 inline.....................
2,378 cc 2.4 liters in-line 4 front engine with 87 mm bore, 100 mm stroke, 9.5 compression ratio, overhead cam, variable valve timing/camshaft and four valves per cylinder 4G69
-Unleaded fuel 87
-Fuel economy EPA highway (mpg): 28 and EPA city (mpg): 22
-Multi-point injection fuel system
-13.2 gallon main unleaded fuel tank
-Power: 121 kW , 162 HP SAE @ 5,750 rpm; 162 ft lb , 220 Nm @ 4,000 rpm
Old Mar 6, 2006 | 02:24 AM
mphil804's Avatar
Thanks for the info. Could you tell me if it can take the higher grade ethanol fuels? Or is it limited to unleaded 87?
Old Mar 6, 2006 | 02:30 AM
[:-] you can go 91-93 and below, but higher grade (racing fuel) hmm...dont think so.
Old Mar 6, 2006 | 02:38 AM
mphil804's Avatar
I probably phrased my question wrong. For example, in North Dakota, there's a fuel mix available that's (to my recollection) 40 or 50 percent ethanol mixed with gasoline. Hahah, I didn't mean reacing fuel, though I could see how it would be understood that way. : )
EDIT: I checked and it's called E85.
Old Mar 6, 2006 | 03:08 AM
a mixture of 10 % ethanol and 90%unleaded may be used,provided the octane rating is at least as high as recommended for unleaded gasoline.
octane requirement:
vehicle (mitsu.)design to operate at min. octane rating 87 and octane rating 91
mixed w/ 10 % is o.k.
Old Mar 7, 2006 | 06:35 PM
dirtwagon's Avatar
Just to be a pain I'll point out a miniscule detail ...The ralliart package is 162 HP and 162 torque. The LS is 160 HP and 160 torque. The 2.4 was not an option, it was standard equipment on the Sportback.
Old Mar 8, 2006 | 10:19 AM
ISLAND MITSUBISHI's Avatar
wow alot off people do there homework.
Old Mar 8, 2006 | 06:31 PM
ORIGINAL: ISLAND MITSUBISHI
by the book bro....lolz[:-]
Old Mar 9, 2006 | 12:05 AM
venum's Avatar
Do the sportbacks have a turbo model?
if so what engine does it have?
