Where is 2014 mitsubishi lancer power window relay?
https://www.autogenius.info/mitsubis...e-box-diagram/
8 7.5 A/C-ECU, column switch, combination meter, ETACS-ECU, key reminder switch, KOS-ECU, power window relay, wireless control module <vehicles with KOS> and receiver antenna module <vehicles without KOS>
1. My interpretation is this No.8 fuse protects all these above circuits involving all the above components?
2. Where is this "power window relay"?
Thank you for your reply!
I posted the whole story here: https://mitsubishiforum.com/forum/mi...71/#post333317
1. Can you please give me some guidance on the next step? I am learning everything from scratch.
2. Shall I buy this manual, or is there a better place to find this info? https://www.faxonautoliterature.com/Product/Index/35401
Hi! Yes, indeed - the relay circuit is integrated into EMACS. That's the way it is. I found out about it when I was installing car blinds. Car windows are transparent, and we do not see anything surprising. The transparent glass guarantees an excellent view from the interior, but at the same time, it allows pedestrians and other drivers to observe what is happening inside the car. In addition, because transparent glass perfectly transmits sunlight, plastic elements, metal, fabric and wooden interior heat up on hot summer days. Now, I am protected from all this by car blinds, which I purchased with the help of https://snapshades.com.au/.
