00' Mirage 1.8 Engine light
Old Sep 24, 2008 | 09:32 PM
Jenniloveless's Avatar
Default 00' Mirage 1.8 Engine light
OK so here it is, have a 2000 Mirage DE auto 1.8. I'm getting a PO420 code for a bad catalitic converter. Pulled the part and it doesn't seem bad.....??? Current plan is to replace the part but, seeing as this is a $$$ eater looking to see if anyone knows if it could be throwing a false code.
Facts:
1. has stalled a couple times on cold start
2. if I clear the code it comes back in a couple of days
That's all I got.
Any help is much appreciated!
Old Sep 29, 2008 | 08:03 PM
Lil Evo's Avatar
Default RE: 00' Mirage 1.8 Engine light
go to a scrap yard and get a new cat and just bolt it on. or, upgrade your exhaust and go with a test pipe. There's a way to wire up the 02 sensor so that it doesn't throw a CEL, but i don't know what it is. google it, or try going to mirageforums.net and search. i've seen it done on a friend's car, but since i've still got the cat on mine i don't know the bypass off hand.
Old Oct 2, 2008 | 02:13 PM
BEAT's Avatar
ARE YOU SURE IT IS THE CAT BACK OR JUST THE O2 SENSOR
Old Oct 2, 2008 | 04:20 PM
dsm1990gsx's Avatar
Your gonna need a catalitic converter and you wont find one at a junk yard, they usually cut them out for $$$. If you run a test pipe in place of the cat converter you'll need a "dummy" o2 sensor which can be gotten anywhere.
As for the stalling on cold starts, a bad cat converterwont cause that.
Old May 3, 2013 | 04:55 PM
mycarlisa's Avatar
usually its the sensor and not the cat. i would try switching out the sensor first and then if that fails the catalytic converter. cheapest solutions first.
Old May 3, 2013 | 10:46 PM
Thanks for replying to a five year old thread.
guyjg
Nov 13, 2021 03:27 PM
pgb205
Jun 4, 2009 10:40 PM
riphamra
Oct 8, 2008 03:44 PM
serenabkhan
Nov 23, 2007 05:44 PM
Powertech
Mar 29, 2006 01:10 AM
