99 Mirage P0120 Code
Old Apr 30, 2008 | 12:26 AM
999mirage's Avatar
Default 99 Mirage P0120 Code
Hi, i'm new on this forum and my 99 Mirage 1.5 de coupe has a chronic p0120 trouble code
P0120 Throttle Position circuit.
I've already replaced the TPS sensor, and that didn't change a thing. The car hesitates when i touch the throttle and at low speeds the throttle cuts out intermittently. I've seen a lot similar problems... but not sure what to do to fix this. The spark plugs and air filter are new.
Thanks =)
Old Apr 30, 2008 | 01:42 AM
Hyphy Crunk's Avatar
Default RE: 99 Mirage P0120 Code
i dont know mine does it, with no error code and no check engine light on.
when you find out what it is let me know :]]
mine does have 289,000 miles give or take a few hundred miles.
mine may just need a complete rebuild.
is yours a high mileage car??
Old Apr 30, 2008 | 01:11 PM
EACISR's Avatar
are u sure its the code P0120?i look it up i couldn't find that code at all?
Old Apr 30, 2008 | 04:07 PM
999mirage's Avatar
yeah, it's P120, has been since i've gotten the car
https://mitsubishiforum.com/m_138857/tm.htm
this is the OBD II codes list in the diy thread
P0120 Throttle Pedal Position Sensor/Switch A Circuit Malfunction
My car has 118K miles. The TPS was replaced at around 109K.
Old Apr 30, 2008 | 08:50 PM
Lil Evo's Avatar
is it positioned correctly? i had the same problem, ended up having to bite the bullet and take it to a dealer to have them adjust it cuz i couldn't get it quite right. i'd also check your wires, cap & rotor just to be sure.
Old May 2, 2008 | 03:38 PM
999mirage's Avatar
Thanks... I'll have to do that and let you know how it works........
ronald321
Nov 27, 2012 03:21 PM
isaacarus
May 12, 2008 06:33 AM
josetello72
Jun 29, 2006 02:08 PM
Georgie Mirage
Mar 28, 2006 04:57 PM
art1217
Apr 25, 2005 07:56 PM
