Horn sounds when very cold outside
hahaha, i think your car is posessed, try a priest. electrical problem somewhere, could be a million things. the only way to find out is to look at every single wire, make sure it's not stripped or grounded improperly.
eh, just disconnect the damn thing...
No really the problem is that your horn is old and needs to be replaced... Something has probly dented it, and so when its cold, the unit shrinks, and contacts the ground... replace it, or just unhook it... your choice.
The last suggestion seems plausible, but I have an '01 Montero Sport with the same problem. Once it gets cold the horn goes off and I have to pull the fuse. After some research, lo and behold, a whole bunch of Mitsu owners have had the same problem. So I think it may be more than just a bad horn and hopefully someone will come up something. I'll start witha new horn, but I'm interested in the cause beyond just treating the symptom.
raskalla
Dec 17, 2013 01:27 AM
armymen
Apr 20, 2012 11:39 AM
2000, 2006, cold, coming, disconnect, galant, horn, lancer, location, mirage, mitsubishi, problems, sounds, stuck, temperatures
