OBD II Code P0420 1997 1.8 Mirage LS 145,00 miles
Old Aug 27, 2014 | 04:24 PM
jssjr5591's Avatar
Default OBD II Code P0420 1997 1.8 Mirage LS 145,00 miles
Been having intermittant Check Engine light problems. Found out today that it is a Catalyst System Efficiency below Threshold. From what tech said it needs a new catalytic converter. Is this something you can do yourself. Also any ideas on cost. He said universal with welding would $80 plus os oem would be upwards of $400. Any thoughts and recommendations. Runs good except on real fast acceleration...guessing that is caused by cat converter being clogged. Thanks for any and all help.
Old Sep 9, 2014 | 01:56 PM
BCloud's Avatar
This is a very common code. I am myself experiencing the same check engine light. There are a number of alternative fixes you can try before spending the big bucks.
P0420 Mitsubishi Catalyst System Efficiency Below Threshold Bank 1 OBDII Engine Light Trouble Code | Engine-Codes.com
Changing O2 sensors is another possible cheaper alternative, and has resolved the issue from some people. I would hate to spend that much money and all it needed was a new O2 sensor.
For me the light is not permanently on and everything I've read says this is a code you ignore until you do see performance loss.
Old Sep 11, 2014 | 06:52 AM
jssjr5591's Avatar
Thanks BCloud for the info. What I've done is to clear code by disconnecting battery cable. I have driven it about a week(300 miles) and have not noticed anything. Today I will check my gas mileage to see what it is now.
Old Sep 11, 2014 | 01:18 PM
Akzle's Avatar
can you positionally weld thinwall pipe?
Yes? You can diy.
No? You cant.
Issues under heavy load can stem from any number of things.
Try the cheap options first.
TheRock0720
Jan 5, 2012 12:30 PM
fords77
May 22, 2011 11:19 AM
bagaak
Feb 16, 2008 07:36 PM
Stryker
Sep 16, 2007 08:36 PM
Britvalencia01
May 13, 2006 11:18 PM
