01 Montero Limited brake noise
Old Aug 5, 2010 | 04:18 PM
driverswanted1966's Avatar
Default 01 Montero Limited brake noise
when the brake pedal is depressed the abs pump is making a pinging/grinding sound for a few seconds.. is quiet.. than comes right back again. tried pulling the abs fuse and it still continues to do this.
I pulled the fuseable link on the positive side of the battery terminal with the picture of (!) around it. not too sure what this does but it makes it go away, but than the pedal is hard as a rock and only the front brakes work.
what causes this to do this?
hope what i explained makes since to somebody on here
all help appreciated
thanks,
andrew
Old Aug 6, 2010 | 10:18 AM
Mr. Z.'s Avatar
Have you checked the brake booster accumulator?
newoutlanderfan
Mar 13, 2025 05:52 PM
overdrive
Apr 9, 2018 04:44 PM
tdf
1st Generation
13
Nov 24, 2011 07:49 PM
lovinmrv
Aug 9, 2009 11:18 AM
2bdetermined
Sep 13, 2007 05:26 PM
