2001 Montero limited front brake pad replacement
Old Jul 27, 2009 | 01:48 PM
lovinmrv's Avatar
Default 2001 Montero limited front brake pad replacement
How difficult a procedure is this? Are there any step by step guides available for reference? I haven't been able to find any.
Thanks,
Old Aug 5, 2009 | 10:40 PM
Default Good learning opportunity
If you have any experience working with brakes it will be pretty easy. If this is a first time, make sure to read instructions and and understand them before you get going, but do not be discouraged. I have the same vehicle and I have replaced brake pads myself on all 4 wheels. I got diagrams and specs for torque and installation procedures from www.alldatadiy.com This is a subscription service, but woks for me. I am not sure if there are books available for this model. I would recommend going with the Mitsubishi pads. They may be a little more expensive then the no-name brand, but they do not create tons of the brake dust - the kind you see (rusty brown wheels) on some vehicles. Good luck.
Old Aug 9, 2009 | 11:18 AM
lovinmrv's Avatar
Thanks Hunterd,
You're right. Really simple...two bolts on and off. Now the bad news....front right showed little wear on outside pad, inside was shot. Need a new rotor and, I assume, a caliper. Any hints on parts sourcing? I assume I should do both rotors, but both calipers, as well?
Thanks
lovinmrv
Sep 7, 2009 11:19 PM
scrimshank
Apr 14, 2009 11:57 AM
areyes0108
Apr 25, 2008 11:10 PM
Torque
Jul 31, 2006 02:59 PM
RakMej
Jan 27, 2006 02:35 AM
