01 Montero Sport 4X4 Tune up/Timing belt..Help
RE: 01 Montero Sport 4X4 Tune up/Timing belt..Help
1I finally got the timing belt job done..It was easy getting to the timing belt..But the things ya run into is just a real pain in the ****..All the reading I did on changing this thing out,and no one ever said anything about having to take the water pump housingloose and replacing the gasket behind itIt's a good thing the timing belt kit I got from partsdinosaur.com came with the gasket,but the o-ring was the wrong size..Also the tensioning tool is an absolutely must! All in all I saved a boat load of money..So it was worth it..Next time will be super easy..
Thanks, for the follow up. I had the same problem with the O-Ring being the wrong size. Of course, by then it was 11:00pm and night, and I needed the car to be running by morning. The O-ring looked OK, so we will see if it continues to last.
GAMonteroSport02
11-20-2017 10:51 PM
Sean Lee
05-12-2012 01:34 AM
woodsman
03-08-2012 02:29 AM
ultramindbrk
12-30-2006 08:24 PM
jbroxton
06-19-2005 06:47 PM
