01 MONTERO SPORT SPARK PLUGS,LOCATION
Old Jan 28, 2006 | 01:25 AM
TRIFILO's Avatar
Default 01 MONTERO SPORT SPARK PLUGS,LOCATION
hELLO THERE ANY ONE OUT THERE KNOW HOW DO YOU CHANGE THE SPARK PLIUS ON A 01 MONTERO SPORT,PLEASE ADVISE.
Old Jan 29, 2006 | 09:51 PM
jc_ride's Avatar
Default RE: 01 MONTERO SPORT SPARK PLUGS,LOCATION
You have to remove the exhause manifolds and a I believe you also have to remove the air intake and the throttle body. It will take the better part of the day if everthing goes well.
Old Jan 30, 2006 | 01:28 PM
off roader's Avatar
As JC noted, it's a big job. If you do it, be sure you use the OE or better plugs that will last a long, long time unless you want to do the job again more frequently.
Old Jul 7, 2006 | 09:40 PM
jrmdir's Avatar
I agree with the previous posts. There is a great step by step instruction write up at http://www.monterosportonline.com/diy.html. I changed my plugs using this info and had no trouble at all. Just take your time and label all of the various bolts as you take them off. You'll need a new intake gasket - I got mine from NAPA and it was fine. I also replaced my ignition wires while I was at it.
Good luck!
LBlueC2
May 20, 2016 02:09 PM
jijordon
Jun 29, 2010 10:57 PM
galant 05
Nov 12, 2008 06:10 PM
Invader_Akira
Oct 15, 2008 08:03 PM
bcolins
Mar 5, 2005 08:44 PM
